ARB compressor location?
Buddy of mine put his in the rear of his vehicle. If you take the little vent out at the far right/rear, there is plenty of space. This would be opposite side if you have rear A/C. Works very well... there is easy access to the underside (for connecting to your lockers) and he even put a air jack right out the side of the below the tail light.
I mounted mine there as well with a bracket that holds it down. I did not want the heat or the elements to get to it.
