Autocom/Delphi scanner pulling weird ABS codes
I used Supersport's software and videos to get a chinese Delphi scanner up and running. It worked perfectly - Supersport you are my hero. THANKS!
It's a very interesting tool. I pulled some climate control codes from my Volvo that will hopefully help me figure out why the compressor is acting weird.
With the Rover, I pulled the ABS codes and got 4 codes that are not standard Rover ABS codes.
115
115
137
138
I have no idea why 115 appeared twice. The Delphi software couldn't identify the codes, it just read them.
I've been googling with no luck so far. Anybody have any idea what these mean?
Also, anybody in the Little Rock area have a ABS Amigo or Bearmach?
115
115
137
138
It will be interesting if you are able to get the codes read with a NanoCom or other scanner so we can match these codes to them. I've seen the 115 code come up before on other's Land Rovers too. It's strange that AutoCom/Delphi does not know what they are. But, if we can cross reference to NanoCom, then we can add these codes to the AutoCom thread for future scans. I MIGHT even be able to add them to the AutoCom Database and add to the Software. I'll have to look into that.
When I read my codes, Delphi specifically told me it was the Left Rear Sensor. When my left rear brake squeels, it throws the code and sets off the Three Amigos. If I immediately reset my codes using UltraGuage, then restart the truck, it does not Hard Set the codes and my Three Amigos go away. If I drive too far with them lit, they Hard Set and I have to use the AutoCom to turn it off.
If you can find someone with this scanner, I confirmed it works: https://landroverforums.com/forum/di...nfirmed-68462/
