Axle Seals
Axle Seals
Oh, so at 40K and 4 years looks like both rear axle seals are shot. Make sure you top up your rear diff oil on a regular basis and if it seems to be taking more or you see a pile of shavings (like 2") on the magnetic drain plug, your seals are probably shot too. It's a good thing I was swapping diffs this week or this would have been unnoticed and untreated.
on
RE: Axle Seals
Axle seals when warn out do not leave metal on your drain plug, that is metal from your ring and pinon and diff that you are seeing.
Yes check your fluid often cause Rover diffs are weak and can gernade themselves easily. I run an 85W/140 gear oil for the extra protection.
By the way, if your hub seals leak, you will see oil on the backing plate of your brakes. This seal can not be replaced and would require a whole new hub assembly.
Mike
Mike
RE: Axle Seals
Yeah, finding that out. We're going to look at making them rebuildable because $650 each is utterly insane for seals and bearings. Yeah, I know the shavings are from metal , there was far more slop than there should have been. We've fixed that, but now if we can't make these rebuildable then I'll have to fork out for another $1300, which is crazy. Know anywhere cheaper to get them? (that's CAD but they're fairly close these days)
on
RE: Axle Seals
Here is the other option, http://www.roverlandparts.com/index....TS&Category=97
for good guaranteed used hubs.
Mike
Mike
RE: Axle Seals
Thanks, that looks like a viable option. Just end up having it on their hoist for an extra few days since they don't work weekends. Which also sadly means I won't be able to get my speakers in, even though they're arriving tomorrow. Unless I get them to re-assemble using the old hubs and just change them myself next week.
RE: Axle Seals
I haven't put in HD axles yet but they're on the list. I'm not doing any severe use in the next while though and tires are only 32". Just new expensive things keep coming up... as they always seem to. Thanks for the offer, I'll be sure to ask if I have anything strange happen.
TRIARII
10-09-2014 08:34 PM
cationmoted
10-19-2012 07:39 AM
treant985
08-05-2012 06:23 PM
