Back with no resolution to my drive issue... Please help
I replaced the motor in my 02 disco a few months back. When driving I would take my foot off the gas and the rpms would drop very low, sometimes causing it to stall. I tightened up the throttle body to keep it from stalling but now when I take my foot off the gas at a coast the truck will feel like it downshifts and will slow down as if the brakes were being slightly pushed. (very noticeable, kinda pushes you forward). During this time if I were to get on the gas again there will be a clank sound in the tranny area (pretty loud). I replaced the tranny fluid and filter, topped off the fluid correctly but it didnt help. I was told that there may not be fluid in the torque converter after replacing the motor but was also told that the torque converter would fill itself during driving and if the converter was at fault there would be codes but I do not get any codes. The only issues I have that I already had are the three amigos. Any suggestions or ideas are greatly appreciated since I am desperate to figure this out.
Did you have someone else replace the engine or did you do it yourself? The reason I ask is that I have seen instances where the torque converter bolts weren't fully tightened and they made a similar noise to what you describe. What I think happens is that the tech starts each of the bolts and leaves it slightly loose, rotates the engine to the next bolt hole and does the same thing on each successive hole, the reasoning is that if you tighten the first one you may not be able to start the next one (there is a bit of "slop" in the holes). This is what I do as well, but sometimes when all the bolts are in, the required tightening of all the bolts doesn't occur. (for whatever reason, lunch, phone rang, pretty girl walked by the window) but it does happen. Just a thought.
stuff
Hey Alan, yeah, its something else. It happens often but not all the time and the lag will hit maybe 2 seconds after I have lifted my foot from the gas. It kicks in and kinda throws you forward.
Thats a good point Bkreutz, I did the swap and remember doing the tc bolts. I actually dropped the oil pan when I did it because The pan needed a gasket so it made it easier.
