-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Battery terminal fix (https://landroverforums.com/forum/discovery-ii-18/battery-terminal-fix-37038/)
NiteTrain Jan 4, 2011 04:25 PM
2 Attachment(s)
I've seen a few people mention this on here but couldn't find any pics so I thought i'd post some of my fix. I cut the old terminal with a dremel tool on 2 sides, pried it apart with a screw driver, pulled it off and put on a universal terminal I had laying around the garage. I messed up a few of the outter copper strands with the dremel because I had poor lighting, foggy goggles and rushed the job but I think it will be ok. Excuse the poor cellphone pics. EDIT..this is the negative side, it will be more difficult to do the positive since it has 2 separate cables.
Attachment 46108
Attachment 46109
antichrist Jan 4, 2011 06:26 PM
3 Attachment(s)
I hope you're not planning on leaving it like that.
A lug crimped well:
Attachment 46105
sealed
Attachment 46106
and connected to a good terminal.
Attachment 46107
Will give trouble free service.
NiteTrain Jan 4, 2011 06:45 PM
I don't see a problem with it, it's on there tight and will not corrode if I keep anti-corrosion spray on it. The old one could not be tighten and could be taken off by hand. I do like those crimped ends though, where did you get those and what did you use to crimp them?
antichrist Jan 4, 2011 06:58 PM
They are ok in a pinch, but don't provide as good an electrical connection, don't protect the inner wires from the atmosphere and, importantly, don't provide any strain relief for the conductors.
I'm sure it's better than what was on there. ;)
I make my own cables (and will for anyone who needs a set).
It's just a hammer blow crimper.
willrok13 Jan 4, 2011 08:26 PM
I'm going to need to do the same thing as I installed an Optima and the negative cable is about two inches short. Any chance I could get a set like Antichrists'?
hilltoppersx Jan 5, 2011 05:31 AM
Tom where did you get the cable lugs from? I am looking for that exact kind for my mil-spec terminals and cannot find them locally
antichrist Jan 5, 2011 07:29 AM
Let me know how long you need it (I'm not sure how long the ground it on a DII) and if you also want the battery to body ground (I assume you do) and I'll quote you a price.
I'm not sure, I have a box of them and all I'll need for a while.
I would think NAPA would have something as good. Or I can send you one or two. They're $3-$3.50 each, depending on what size cable. Not cheap, but not cheap in quality either.
hilltoppersx Jan 5, 2011 10:06 AM
the kids that work at my local napa are a bunch of idiots... ill go down there and see if i can show them a picture of what i need. if not i might have to take you up on that offer and buy 3 off of you.
Long Haul Jan 5, 2011 12:56 PM
Hey Ed heres the Napa belden part #728223 + and 728222 - for the milspec battery terminals. as far as the cable terminals if you tell me the gauge wire you have I'll get you the numbers on that stuff. I still have a bunch of older catalogs laying around from when I used to work there
hilltoppersx Jan 5, 2011 01:53 PM
Thanks Brian I got the terminals i need to check out the guage of the wire because im not sure what it is. They are stock.
