Best Gear Oil and ATF?
RE: Best Gear Oil and ATF?
Well I already did a power steering flush using synthetic and a bottle of lucas additive. I also did the ATF engine flush and switched to mobil 1 synthetic high mileage. I am not sure what to use in the brakes ............ any suggestions? Also, concerning the brakes, do all the fluids mix? I know I need dot 4 but can I switch to a synthetic and not have any problems.
Mike I have read some of your posts on here saying that you use Lucas 85w 140 gear oil. However, I thought that you are supposed only use synthetics in the differentials and transfer case. I thought that the lucas stuff is not sythetic. Am I wrong?
Also, regarding the tranny, I see on the 60000 mile list that it says a bottle of Lucas transmission additive. I was just wondering when this should be added as I have seen on here that the tranmission drain and fill can be a little tricky.
Thanks alot for the help!!!!!!
I use Mobil One High Mileage syn oil.
Gear Box's Mobil One Syn 75w-140 or 75w-90.
The Trans I started to use Mobil One ATF a long time ago.
on
I have been running Vavoline's synthetic brake fluid for years and highly recommend it. The reason I switched to it was because I am also running DBA rotors with Kevlar pads, which generates a lot more heat that the synthetic seems to handle better with out giving you any soft pedal.
As for the 85/140, I mentioned Lucas because they make a pretty good product and it is less expensive then a full synthetic. If you are doing lots of water crossings and change your fluids more frequently, Lucas is a good way to go, otherwise use the full synthetic.
Thanks everyone. Yea I only do wheeling every now and again, and I would like to get the longest between intervals, so I guess I will stick with the synthetic in the diffs and transfer case. Do they make a 85/140 synthetic or should I just go with the 80/90 like the manual says. I know this is kind of a weak spot in these trucks so I would like to get the most protection.
Regarding the brakes, I'm not sure what kind of fluid I have in there now, and I run slotted and dimpled ebc rotors with ebc greenstuff heavyduty pad. So I guess I would like to switch to synthetic. If the two kinds dont mix with one another is it ok to do just a regular two person manual type brake bleed with the new stuff or is there some type of different procedure.
Thanks again
Thanks again
