Best on road shocks?
Please post what you find. My road tires are practically new so I won't be swapping tires for probably 2 years. I also run 18-inch wheels. I was thinking a 2-inch terra firma lift kit for $500 but now thinking just put a stock OEM shock/spring set. My shocks are shot.
I am sitting at 32.5 inches ground to wheel well height. 34.5 inches with a 2 inch lift would look funny with my wheels and tires.
I read Bitpart has a 1.5" kit and OME no-lift is another option.
Problem is I can't find a replacement, medium duty, no-lift shocks and springs kit for the same $500 as the 2-inch kit. Anyone find a replacement kit for all 4 wheels, no lift, for $500?
Put the standard Terra Firma shocks/struts on my D2 last year. Really happy with them and didn't break the bank.
Terrafirma Shock Kit, All Terrain For Discovery 2, Front And Rear
Wonder if I can buy the 2" terra firma lift kit, put only the shocks on now then put the springs later when I change tire size? These shock kits say the shocks can handle 2" of lift so the shocks should work the same on a no-lift and lift truck?
I put brand new bilsteins on old original springs and wore them out in less than 10k miles.
I would not recommend you put new shocks on a high mile original spring truck.
Especially expensive ones.
I have OME MD +2 and after 2.5 years they are starting to ride less stiff. So shop around and know what you are looking for. Stock OEM replacements are a fine option and Lucky8 has them cheap.
If i had it to do over again, for a minimally offroad vehicle, I would get those L8 stock replacement springs and Bilstein shocks.
