Best Way To Drop Oil Pan To Fix Leak
The crossmember should not be too hard to remove unless the bolts are rust-welded like mine and you decide you don't have time to play with that right now. I had the truck on ramps and used 2 x 4's to further lift the body. You lift both sides until the front shaft is hanging loose (tires barely touching the ramps then the pan can dropped and turned upside-down and slipped out.
Be very careful so you don't get the truck on the stomach !!!
A bit of a dirty job but worth cleaning the sedimented dirt in there.
François
François
Phatrowles
01-09-2014 10:36 AM
lipadj46
07-08-2009 07:41 PM
