Bigger 18's?
Does anyone know the biggest size above the 255/55/18 that will fit w/o rubbing. I have an '03 se.
RE: Bigger 18's?
nothing will fit above that unless you want to ruin your truck.
RE: Bigger 18's?
1 Attachment(s)
ORIGINAL: snowdude nothing will fit above that unless you want to ruin your truck. - 285/60 r18. roughly 31.5" Are you planning on offroading? It is cool if your not. But 285/60 is more for street use. You will rub while flexing off-road. these tires are Pirellis. Attachment 49146 |
RE: Bigger 18's?
i have 265-45-20, they fit perfect.
RE: Bigger 18's?
ORIGINAL: nervous4ever Does anyone know the biggest size above the 255/55/18 that will fit w/o rubbing. I have an '03 se. |
RE: Bigger 18's?
I have been running 265/65 18s and they fit just fine. Technical courses no problem.
RE: Bigger 18's?
If you change the tire size, don't forget to replace the spare with the same size! You might need to get an adapter to fit the oversized spare on the truck too.
RE: Bigger 18's?
Thanks Guys. I do some offroading. Mudding not rock climbing.
Will the 285/60 r18 be ok or should I go smaller? |
RE: Bigger 18's?
smaller with no lift for offroading.
RE: Bigger 18's?
Goose, What kind of tiresare you using.
You don't rub at all with 265/65 18s? |
