Bleed screw
RE: Bleed screw
On your year, there's a bleeder built into the hose assembly. If it's the original hose kit that came on the vehicle, it'll actually be in the middle of the hose that crosses over the shroud.....built right into the hose itself.
The newer replacement hose kits have the bleeder built into the T-connector that joins the radiator hose, to the water pump hose, to the t-stat hose.
