Blocked View...
Blocked View...
Question for the panel...I have a 2002 Dico SD, is there a way to remove the headrest on the middle sit in the back. When the armrest is down the headrest is goes down and doesn't block ones view, however, it does make it hard to see when the armrest is up. I hope this makes sense.
Trent
Trent
RE: Blocked View...
That is a new one on me, but I will try to help anyway. disassebly instruction are in most of the shop manuals. You can find them on ebay. they also have a cd version that is cheap. 6-7 dollars. if you have not already done check the search forum here some one may already have the solution to the problem. Some people don't notice that it is available. If you find the problems solution, share it in the forum. it may help another. welcome to forum and hope this helps. gotta love a rover. duboff.
PilotDoofy
09-20-2007 09:10 PM
