Brake caliper bolts seized up
1 Attachment(s)
I've soaked them in PB blaster and even with all of this leverage I can not get them to budge, either of them! Any advice?
Attachment 41004 |
I used a mallet. It was the only thing that could get them to budge. I wacked them pretty good.
And even then, a couple others, I had to jack the truck up, put a jack stand under the wrench, lower the truck and use the weight of the truck to loosen the bolts. Probably not the safest way, but it was the only thing I could do to get mine loose. |
1 Attachment(s)
Thanks man. I tried the rubber mallet to no avail. But I finally figured it out. If anyone else is stuck on the bolts, 1/2 socket, connect the rover tir iron extension bar, and finally connect a four way tire iron. If with over three feet of leverage it took some force to break these suckers lose:
Attachment 41003 |
Damn those suckers didn't want to break free. A+ for persurverance.
I was going to suggest a quick few taps w/ a BFH |
Next question. There is a single screw that holds the rotor onto the hub. Whoever put this back on last time didn't line up that hole so obviously the screw is now missing. Does anyone knows its dimensions? |
Originally Posted by caymandrew
(Post 395137)
Good advice, thanks!
If your having problems with seized bolts, do NOT put that rotor retaining screw back in! That was the worst part of my brake job, the thing did NOT want to come out!
That cheater bar, wow. :O
Another little tip I can add - the pb blaster works, Kroil works better ( Penetrating-Lubricating Oils ), or another product that a couple local garages showed me -
It's basically got some cooling agent to it so you can heat where the bolts go in, then hit it with this stuff causing the metal to shrink faster, often breaking the rust seal. Another tip - hit the head of the bolt really hard. It'll brake the rust free before damaging the threads. Just don't miss and mangle the head of the bolt. Dave |
