Brake issue
Old 12-13-2017, 11:01 AM
LR03NJ's Avatar
Originally Posted by Richard Gallant
Thanks that was the 1st thing on my list, but I figured I might as well ask some advice. Stopping is kinda of critical .
I think thats what everybody do. Save us a little step by getting opinions first. Often we have the idea what needed to be done but because a lot of members here are well capable of help and support, we ask. I do that every time. Plus theres OverRover for hard to find parts and he puts the big RED arrow for you. HEHEHEHEHE
Old 12-13-2017, 05:59 PM
Externet's Avatar
My brakes behave like that. Always, on panic stops, pedal travels to much lower. In 'normal' breaking, pedal is stiffer.
Have not driven another Disco to compare.
Scary but taken as the nature of the beast after finding nothing wrong in the system.
Richard Gallant (12-13-2017)
Old 12-13-2017, 06:55 PM
Richard Gallant's Avatar
Received 1,131 Likes on 781 Posts
Thanks for the feedback, this was significantly lower with a feeling of little pressure, but I did not double pump.
I just went through this kinda of issue with my now retired Pathfinder - master was going but I could get the "standard" indicators. Pedal would not maintain pressure, could replicate pedal loss etc. it came out of no where too.
The Disco did it once on a cold start and has not done anything for the last 2 days - short trips only. Did a test on a small hill, dead end's at the long flat dirt road. She held fine for 10 minutes no pedal loss.
It is a head scratcher, but full fluid change and bleed during the holidays. To eliminate that as an issue.
Old 12-13-2017, 07:45 PM
OverRover's Avatar
AFTER you have ruled out the master cylinder, etc as the cause for the low pressure consider replacing the rubber brake hoses with a braided stainless steel hose set. I run SS hardlines and hoses on every LR, motorcycle, and car that I own even if I have to get them made. Well worth it.
As far as a firmer pedal feel SS brake hoses make a great improvement to a DII. If you have, or are planning to do a lift they also make these hoses in extended lengths. There are many brands like Goodridge and AB has a set too.
Like> Discovery 2 Stainless Steel Brake Hose Kit With Brake Fluid
Richard Gallant (12-14-2017)
Old 12-14-2017, 10:15 AM
On the list for the spring, the wife limits my "toy" funds need to get the transmission, transfer case and diffs serviced 1st.
Old 12-14-2017, 10:19 AM
OverRover's Avatar
She doesn't have The Brakes First on The List.... you might want to check if she took out a huge Life Insurance Policy in your name!!!
Alex_M
11-17-2014 07:34 AM
nate2k5
06-03-2012 05:49 AM
Kingmarine
02-26-2012 09:27 PM
tunernewb92
10-20-2009 07:15 PM
dms98e
05-09-2008 08:36 AM
Quick Reply: Brake issue
