-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Brake Pedal + ABS (https://landroverforums.com/forum/discovery-ii-18/brake-pedal-abs-50092/)
FlyingZebra34 May 29, 2012 08:35 PM
Brake Pedal + ABS
I need to know if this is normal. When I press on the brake pedal while idling the brake is relatively soft but no to soft, it feels "correct" but when I am still parked, and I accelerate the pedal stiffens up a bit.
Also when I abruptly use the pedal I don't get the "3 amigos" I get the ABS light and TC light.
Any thoughts?
drowssap May 30, 2012 06:53 AM
according to your bio you have already flushed the complete brake system?
Disco Mike May 30, 2012 09:02 AM
Have you replaced your rubber brake hoses yet, if not go to stainless steel and reflush, this will give you a firmer pedal.
As for the ABS, if the lights come on at all, you have a ABS issue and must get the codes read while the lights are on.
