brand of motor oil---2003 Discovery
Going to change my oil in the Disco instead of having the dealer do it (Midwest US):
1) Which brand (and weight and specs) do the LR service centers at the dealerships use? 2) Which brand (and weight and specs) do you all recommend? 3) Anything unique I should know before diving in (filters, accessories, issues)? I've changed oil in vehicles thousands of times, but never a Rover. thanks as always............. |
I would suggest Rotella's 15W/40 synthetic Diesel oil and a Mobil 1-301 oil filter.
Do not use what the dealers recommend, they all use the cheapest bulk oil to make more money and it is not always what is best for the truck. Was the 60K done, if not you have a long list of stuff needed, along with new 8 mm plug wires and rebuilding or replacing the front drive shaft before it fails. Also plan on a new t/stat. coolant pressure cap and serpentine belt. See my sticky at the top of this section. |
no it was not------right now I can afford the thrmo cap and little else---that's why I'm changing my own oil. Stinks to be a LR owner with tight funds. Thanks for the info.
U-joint just got replaced a week ago-----there's your drive shaft repair.
I use NAPA Gold oil filters, $6, made by Wix.
Purolator is also a good filter. I also use Rotella, get it at Wal-Mart, $12.50 per gallon jug. |
Originally Posted by kpl1228
(Post 234066)
1) Which brand (and weight and specs) do the LR service centers at the dealerships use? 2) Which brand (and weight and specs) do you all recommend? 3) Anything unique I should know before diving in (filters, accessories, issues)? I've changed oil in vehicles thousands of times, but never a Rover. thanks as always............. For what it's worth......I used fully Synthetic Mobil 1 10w30 until Forrest had around 80k miles then switched to non Synthetic GTX 10w40 high mileage, which I will use until...... (I'm the second owner and Forrest had a little under 40k when I got him). I also use NAPA Gold oil filters, on all my cars. Hope this helps some. C'ya, |
Originally Posted by Disco Mike
(Post 234090)
I can only find that in dino... |
Which Rotella's oil? T1, T3, Triple T, T5, or T6?
(Post 234276)
Bundu-I only get 15w-40 in dino only as well...Walmart:) |
ok---just picked up the filter, will get the Rotella T6 on my way home---15w40
