Brass colored shavings in t-case
Hey everyone,
As the title says we were changing the t-case fluids and found some brass colored shavings in the old lube and was wondering if anyone has a cross this. I checked the gears and they look good so I can only think that it maybe a bushing of some type. Thanks |
Originally Posted by Lowest Bidder
(Post 458510)
Originally Posted by BCDisco2Lando
(Post 458517)
Exactly
Sounds good and thanks for your help.
In your case if a preload shim has disintegrated, it's possible that one of the shafts is now out of spec, meaning the teeth are not perfectly aligned when torque is applied, leading to premature wear. I would certainly keep a very close eye on this, and plan to replace the oil in a few months just to make sure there's no new metal shavings on the magnetic drain plug.
(Post 458584)
Thanks |
| All times are GMT -5. The time now is 03:41 AM. |
