Broke this. Can it be fixed ?
Clip on right side underneath dash that allows access to fuses. ANyone have one break off and is there a fix that doesn't involve taking the dash apart? From what i can see (which is limited) looks like it may have been a piece built into the lower dash panels and not attached.
Thanks
Thanks
It sits in the dash behind the cleco-style fastener. You can reach up with the fuse door open and set it back into the opening. You can use Goop or epoxy to hold it in permanently. After it dries, you'll be able to use it correctly again.
It is easy to break out, if you try to open the door with the fastener not completely cleared.
bcolins
01-18-2015 11:40 AM
