broken tube and power steering
hello everyone! i have 95 disco. not discoII. it has 109xxx miles. i was checking the engine oil level and i broke a clear tube. it connects the throttle body and the distributor/rotor thing. see???
http://img.photobucket.com/albums/v3...brokentube.jpg http://img.photobucket.com/albums/v3...kentubecap.jpg i have no idea what its for and what it does. i looked for it in the rave service manual and i couldent find anything. whats is it for? do i gotta go the the tube from the dealer or can i just go to autozone? also, this thing with the red dot is leaking. http://img.photobucket.com/albums/v3...ersteering.jpg i dried it and drove it for a while and it started leaking again. what is it for? power steering? any advice on what to do? i know you guys say if it isnt leaking it isnt a land rover or something like that, but i dont like my car leaking. i also have some leaking near the oil filter and above the water pump. im going to dry the leaking areas and see if it leaks again |
RE: broken tube and power steering
Any auto parts stores should have some replacement tubing to help you with that issue.
As for the red dot on your steering gear box, how bad is the leak? |
thanks disco mike. what is that tube for? the steering gear box leak doesnt seem too bad. ill dry it out and see how bad it leak again. as soon as it stops raining. do u know why it might be leaking?
oh yeah. is there anyone in the Los Angeles that can pull the codes for my discovery? i done have the money to pay a mechanic $85. i can give you $20 or something.
