A/C help!
A/C help!
so i took my D2 into a shop to get the A/C evacuated and charged, however, its still blowing out the same temp. The guy at the shop thinks there might be something wrong with the condenser and whatnot.
I had noticed that it doesnt blow very cold while stopped, but as soon as i start driving it will get noticeably cooler but not as cold as my other car does.
Anybody have any suggestions on this front? thanks.
At 28C or over the A/C should run with the A/C and ignition/engine on, at least this applies to a TD5. If this doesn't happen check the fan with a 12 volt supply to see whether it's working or not. If it's working check the temperature sender for function. Often the condenser flunks and needs replacement which will require the A/C system draining and refilling with refrigerant.
Be very careful as the A/C system is under considerable pressure.
Sorry to hi-jack. Quick question related to the topic:
If coolant temps rise 6-10 degrees when the A/C is turned on, is this exposing a faulty condensor? My temps currently fluctuate between 183 and 190 most likely due to a stubborn air pocket but immediately upon activating the AC, temp jumps up. The Elec-fan is in good working order and runs according to RAVE parameters. Ambient temps around 100 deg in the afternoon, but situation applies to cooler ambient temps as well.
There was a thread on escalating coolant temps with AC engaged. The OP had a mechanic fix the problem but no explanation or parts replacement was given.
If coolant temps rise 6-10 degrees when the A/C is turned on, is this exposing a faulty condensor? My temps currently fluctuate between 183 and 190 most likely due to a stubborn air pocket but immediately upon activating the AC, temp jumps up. The Elec-fan is in good working o... .
Condensor is basically a smaller Radiator, and its job is to dump heat. First up after the condensor is the radiator, so your coolant temp will rise.
Modern cars have fan control units that see operation of the AC and increase the fan speed, so they tend to get less or no temperature rise.
