A/C not blowing
Not working unless it's moving?
Meaning all the fans work inside, but its only cold when you are moving?
Possible, but improbable. Turn the AC on and look at the electric fan in front of your radiator on the passenger side. Is it on? Is should be. If not, you need a multimeter so we can test through the circuit and figure out why not.
From what you're telling me this sounds less like and AC problem and more like an inside climate control issue (the blower motor, speed control transistor, or the controller itself).
Just trying to make sure I send you down the right path here with things to try.
Here's another idea....did they tell you as part of that ridiculous estimate exactly what work they proposed to do or what parts they were going to replace?
Because....really? I don't think I need to go any further here. If the panel is really that bad, there would be a whole lot of things not working other than the blower fan.
Not that this level of scumbaggery would surprise me coming out of a dealership.
Any sane shop would give you some choices. Like bypassing the problem circuit with an inline fuse.
This isn't a new truck. It's not worth $40+ K anymore. Let's be realistic here.
Good Morning guys,
Thank you'll for responding back to my post.
Yes, as long as the hev is moving I get some very little cold air.
Yes, the dealer wants to replace the whole fuse box( located next to the battery).
Something that I have notice is when I push the bottom in the climate control to make to air circulate, the whole thing stops working( no more air coming out).
If so, this has absolutely nothing to do with your engine bay fuse box, or the inside fuse box.
