A/c shows C* instead of F* ugh
Turn the ignition on.
With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to “F”. Follow these same steps to change your read-out to Celsius , if preferred
Regards friend,
Regards friend,
Why is your owners manual out of the truck?
The security code for the stereo should be in the stereo owners manual.
Otherwise you will have to get it from the dealer.
Print this page and stick it in your glove box.http://www.RoverParts.com/TechTips/T..._C_to_F_D2.cfm
