-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   came up with a idea for diff guards,,, (https://landroverforums.com/forum/discovery-ii-18/came-up-idea-diff-guards-25774/)
sloppyjoe Oct 12, 2009 11:19 PM
it occurred to me today that the weakest part of a diff housing is the back of the diff (or front of the diff if talking about the front). the metal in those areas are the thinnest and can easily be dented or punched in causing damage to the ring gear which is spinning not more then an inch from the housing.
SO,,,, i have come up with a simple idea and ran it buy a few hard core off road guys at the metal fab shop. gonna make a couple prototypes to attach to my my rig.
rock rails i should have prototypes within a month or so and grill i should have some design soon. need to determine material for the grill surround. thinking aluminum or light gauge steel.
probably light gauge steel as it is cheaper and easier to weld. key is keeping costs down for you guys but still making something that you guys pull from a box and think is a work of art.
antichrist Oct 13, 2009 05:32 AM
There are a lot of diff guards on the market. The most fool proof solution is a pipe cap that costs about $50.
lipadj46 Oct 13, 2009 08:31 AM
I've seen the pipe cap, works well. Plus you get 2 guards from 1 cap. Requires cutting and welding skills though.
Disco Mike Oct 13, 2009 08:50 AM
Yes, they are good, but do nothing to protect the bottom or u-joint area. Then there is the question of the rear diff, put a cap on it for when you are going backwards, but what about your normal wheeling, it won't do squat for that diff.
Urban Panzer Oct 13, 2009 11:10 AM
QT front and rear diff guards.................Nuff said ;)
antichrist Oct 13, 2009 11:18 AM
The bottoms will take a lot of abuse.
I don't recall any diff guards on the market that also protect the u-joints (not to say there aren't any), but there are several u-joint protectors on the market.
Joe didn't mention any plans for his to also protect the u-joints.
sloppyjoe Oct 13, 2009 11:18 AM
once i have mine cut on a laser and put in place you will see what i am talking about,,,
sloppyjoe Oct 13, 2009 11:19 AM
i have seen the pipe caps and am not a fan for some reason
antichrist Oct 13, 2009 02:50 PM
Yeah, I suppose some people might not like the looks, but you can't make a stronger one that's an add-on.
Disco Mike Oct 13, 2009 03:03 PM
QT makes a great diff guard.
