can you tell me if these look like the stock Drive Shafts?
not sure if they are the originals or not, i'm getting a vibration around 20-40mph when accelerating only. i think it could be the drive shaft but not sure. let me know if you think these are the originals, if so i know they suck and need to be replaced. they look original to me.
front drive shaft connection to transfer case
read drive shaft connection to transfer case
on
If you only have 1 grease fitting on that front shaft, it is original. You can order the parts anywhere but if you haven't rebuilt a double cardon drive shaft before, your's is not one to practice on. Find a drive line shop, tranny shop or someone who has done lots of them before, make sure they replace both the u-joint with greasable one and a new centering ball kit.
