can't get grease out of the front driveshaft
How long ago did you rebuild? Is the grease just squeezing out around the zerk? If you can't move grease through the u-joint, it is toast. As grease gets older, it gets cooked by the heat from the cat. Keeping the grease fresh keeps it working. Once it's solid from the heat it loses it lubricity.
After redoing mine, I could only get grease out of 2. I ziptied a scrap of paper towel around the joint with the most discharge, and was then able to get machine grease out of the other two.
I then drove it around for a couple hundred miles. After that, the grease came pretty easily out of all 4.
