CDL shifter not budging
Old Jan 9, 2015 | 06:19 PM
DiscoFever88's Avatar
Default CDL shifter not budging
I have recently purchased a 2004 Disco and the other day me and a buddy went out to play and when I went to lock the CDL and the shifter would not shift left. No matter what I did it wouldn't budge. It moves fine from high to low with it unlocked. Ive looked up under at the transfercase linkage and it doesn't look corroded or stuck. Ive looked up all over forums but cant find anything but switching older discos to CDL or installing new levers. Help please! I had to have my buddy winch me out with his little jeep and I'm hearing about it everyday.
Old Jan 9, 2015 | 06:49 PM
Bom2oo2's Avatar
If u have looked under truck, U should see the cable that moves the CDL small arm, but U can't see the arm itself, reach and feel it with your fingers, once u find it there is a nipple (the arm actually turns that nipple 1/4 turn) use a wrench or (any tool u like) to turn it. Most likely cable is stock but u will be able to turn it loose. Use lubricant between cable and it's sleeve to keep loose. Move The shifter few times a week so it doesn't get stuck again. Also can try lubing from top more work but better . (This is if nothing Broken)
Old Jan 9, 2015 | 07:14 PM
dusty1's Avatar
yep. going to have to do it with a wrench 13mm me thinks. need to work it lose
Old Jan 9, 2015 | 08:15 PM
thanks fellas ill be doing this in the morning. which way should i be turning it to lock it?
Old Jan 9, 2015 | 10:53 PM
Bom2oo2's Avatar
This shows the guy turning the nipple with wrench. I hope it helps to visualize what u need to do.
Old Jan 10, 2015 | 10:21 AM
abran's Avatar
I case the video is not clear...
Clockwise to lock.
turbodave
Mar 29, 2019 07:22 AM
Dexlen
May 12, 2009 09:05 PM
jycsalas
Apr 13, 2009 12:17 PM
Jull
Oct 29, 2008 10:42 AM
rcshauger
Oct 3, 2008 05:36 PM
