CDL shifts fine into all positions but no light or audible chime
The high/low cdl linkage shifts flawlessly with minimum effort (in contrast to my grey D2 where mild force is always necessary) however theres nothing showing up on the dash and no chime, typical whenever a gear is selected. Where should I start? Could this mean the cdl was disconnected or perhaps a fuse or a sensor malfunction?
The xyz gear selector switch was bad and the m/s lights were flashing when I received the truck. I played around with the cdl and assumed that the function was disabled due in part to a faulty xyz. I ended up replacing the switch with a older used unit. The one that I pulled from the white D2 has a black plastic back piece whereas the older versions are a tiny bit smaller and have a yellowish plastic back piece. With everything back together the m/s lights are gone and the truck runs as normal except when you shift into either neutral or 1st the dash does not acknowledge. Neutral can be acknowledged if I jiggle the automatic shifter a tad bit, but as soon as you let go the dash does not acknowledge neutral. So with neutral selected Im able to shift the cdl linkage into all positions but again no dash icon an no chime.
PS: The xyz switch is not as hard to replace as some folks had me to believe. The plug was securely snug in the harness bracket and would not come free so I had to improvise. The plug now hangs loosely not secured to any bracket. I did have to remove one bolt from the heat shield and peel it back a ways in order to slide the switch off the shaft. I also found the job much easier if and when you remove 2 small bolts that hold the switch bracket in place as seen in pics. Doing so allows you to easily reach up and pull the switch plug down a ways where you can manhandle it.
It could be the transfer case n switch or the cdl switch inside the TC are sticking or aren’t even hooked up! The 04 I have wouldn’t beep when in N and it wouldn’t change the Sport Mode to Manual Mode. I changed the transfer case fluid & used the diff lock & 4lo and drove it down a dirt road for a bit in low. Next time I shifted all was well and it now works as it should.
You may have to adjust your XYZ switch to get proper gear indication on dash. Sometimes it works better if you have someone inside, while you move the switch. The switch mounting holes are oblong, for minor adjusting.
Have you physically checked to see if it is going into CDL lock? (lever underneath moving stud) Lever may be loose on stud and not actually activating CDL.
Brian.
Brian.
I tried adjusting the switch prior to install but could not get the plastic round piece to rotate. I did not want to chance damaging the threads. Seems the switch could really only be mounted on the shaft one way then once in place I had to rotate the switch until the bolt holes lined up. I have not examined the cdl linkage underneath as of yet. Ill have to take a look when this storm passes.
Update
So the transfer case has fresh fluid and a new cover gasket. Still no audible ding or illuminated light on the cluster, when either low range or cdl is engaged. The low range is functional however; tested it on a steep hill and it worked fine. But again no audible or light. Could it be possible that something in the cluster is either disconnected or faulty?
On the '04 cases there are two CDL switches, wired in parallel. Hard to imagine both failing... I bet they're disconnected. I would check to make sure they are connected, then either use a lynx/nanocom/hawkeye to test the CDL lamp, and/or short one of the switches to see if CDL illuminates.
There isn't a light on the dash to signify low range, unless I'm dumb and never noticed it? There's only the audible warning when switching to neutral.
Where on the transfer case can I find the 2 switches mentioned above. Are they easily accessible from underneath the truck or do I need to pull everything apart from inside the truck?
