Change t/case and diffs fluid and jacking up rear of Discovery II 2000
Okay, just to confirm, the t/case and both diffs take the same fluid...Correct? I read in another thread it is recommended put 85w/140 for all three. Does that sound right? Also, how many quarts should I buy to change all three?
what do you guys thinks about using Lucas high performance heavy duty gear oil, SAE 85w-140 for all three? I can buy it at Auto Zone for $7.99 per qt.
here is the link: http://www.autozone.com/autozone/accessories/Lucas-Oil-1-qt-85W-140-high-performance-heavy-duty-gear-oil/_/N-25t1?counter=2&filterByKeyWord=Lucas+Oil&fromStrin g=search&fromWhere=Brand&itemIdentifier=693859_0_0 _[/URL]
Finally, is it okay to jack up the rear of my 2000 discovery II by going under the rear differential/pumpkin?
thanks!
thanks!
Yes, though I would use jack stands under the axles before I crawled underneath.
