Changing Tcase fluid
I saw on the fill plug on the Tcase and I assume its like the Diffs and uses a 1/2' ratchet, but it looks a little tight behind the ebrake drum, would a universal work/fit to get the fill plug out? Or any tips?
04 DII |
RE: Changing Tcase fluid
i use a 1 inch wobble extension
That is all you need.
| All times are GMT -5. The time now is 08:43 AM. |
