check Valve in right valve cover
Old 08-15-2018, 11:40 PM
piperff's Avatar
Default check Valve in right valve cover
Needed, I assume this valve is part of the PCV system...mine is sooo stuck...disco 2 ..4.6
Old 08-16-2018, 12:00 AM
Received 1,131 Likes on 781 Posts
Yup and you cannot get it out on an 04/03 with out removing the valve cover in 90% of the cases, but carb cleaner sprayed down there 8 or 9 times will clean most of the goop out. Work wonders on mine an killed my oil consumption completely.
Old 08-16-2018, 01:27 AM
piperff's Avatar
Thanks Richard, Anybody sell these?
Just finishing up on a cam and lifters on my 03/D2, looking at details as I reassemble..Thanks for the info,will try carb cleaner trick..JV
Old 08-16-2018, 02:56 AM
JUKE179r's Avatar
Remove the ****ty plastic PCV, throw it away and screw in a FRAM FV308 PCV to the manifold cover.
Inline PCV - Best4x4
The following 3 users liked this post by JUKE179r:
GarySpringfield (10-18-2019), piperff (08-20-2018), Sixpack577 (08-16-2018)
Old 08-16-2018, 06:35 AM
If your talking about the oil separator then just grab it with pliers and wiggle it out
I just did mine it's metal stud with a pin hole on top and inside it has a plastic oil separator
i drilled that plastic out and will be installing a fram pvc valve
Old 08-16-2018, 06:49 AM
Sixpack577's Avatar
I did Best4x4's Fram PCV valve too.
The following 2 users liked this post by Sixpack577:
Old 08-16-2018, 08:40 PM
Extinct's Avatar
Received 1,402 Likes on 1,002 Posts
Originally Posted by Sixpack577
+1
+4 No more oil leaks!
Old 08-17-2018, 11:12 AM
Any pics of this mod ? Did you guys keep the metal fitting in and attached the new pcv or did you guys put the new fram pcv in the hole
Old 08-17-2018, 11:20 AM
Best4x4's Avatar
Received 2,237 Likes on 1,660 Posts
Remove OEM plastic nipple from intake, screw in the FV308, and if you can remove the baffle from the valve cover for the best results.
Old 08-17-2018, 12:13 PM
Oh I'm talking about the oil seperator mod with a new fram pcv
Quick Reply: check Valve in right valve cover
