Chirping Noise From Vent
I have a high pitched chirping noise coming from the drivers side vent when the engine is on. Any ideas on what it could be?
I have the same sound, and i think it is the fan... it either needs to be replaced or oiled or cleaned or something, but bottom line is it's pretty annoying!
Regards, |
Annoying indeed!
It is sooo annoying! I'm just hoping that it is something as simple as the fan...
I would pull the fan out from under the glove box and check to see if you can oil the bearing, it only takes 10 minutes to pull the blower motor.
I had the chirping, its the blower motor, warranty replaced at 99k
