choke cleaning
on
RE: choke cleaning
I agree, you have no choke. First thing to do would be to remove the air intake tube from the throttle body, and use some carb spray and a wrag to clean out all the built up carbon on both sides of the throttle plate. Next thing to do is have someone clean your IAC motor, idle control unit.
Between these two items you should be set.
Mike
Mike
05LandRover
04-26-2006 10:27 AM
