-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Clicking noise under the dash (https://landroverforums.com/forum/discovery-ii-18/clicking-noise-under-dash-65279/)
cbwhitley Feb 18, 2014 07:05 PM
Hello all
Got a question about a strange clicking noise under the dash when my 2004 discovery is started. When I start it it clicks about 5 to 10 seconds and stops. What can this be???
00&04 Disco Feb 19, 2014 04:56 AM
Where is the sound coming from? Left, right, under steering column?
cbwhitley Feb 21, 2014 04:37 PM
Sounds to me like it is coming from under the steering column. Sounds like some sort of vacuum leak that has to build up pressure ..pop a..pop a..pop a..pop a...than then quits
SuperSport Feb 21, 2014 05:18 PM
Without hearing it, total guess, but how about blend doors? Kinda sticking?
zski128 Feb 21, 2014 06:33 PM
Theres that little temp sensor fan behind the little slats to the left of the steering column. It was all clogged up on my 2004 when we first got it and caused a clicking noise.
jfall Feb 21, 2014 07:52 PM
I bet I know.
The brake pedal switch is going bad.
The brake pedal switch is a compound switch that operates the solenoid that keeps your gear shift locked in Park until the brake is pressed.
If you are lightly resting your foot on the brake pedal that could do it.
Or
the switch is going bad.
The noise is really from the console area? correct? A clicking..
cbwhitley Feb 23, 2014 07:53 PM
I think the blend doors might be it. There was a time this winter when the engine was warm and was still blowing cold air. I cranked the temp control to low and then moved it up to high and the heat worked again. How is this fixed .
SuperSport Feb 23, 2014 10:29 PM
I haven't dealt with them on the land rover yet, but on other vehicles, it's a matter of finding all the pivot points and lubing them, and make sure the vacuum lines are not broken and are connected everywhere. There is also the main switching valve for the vacuum lines. Make sure it's working. It's a lot of tearing apart and searching...
