-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Clicking under shift lever when brake pressed (https://landroverforums.com/forum/discovery-ii-18/clicking-under-shift-lever-when-brake-pressed-77426/)
jamieb Jan 23, 2016 05:58 PM
Just did the option B for brakes. Coincidentally, now when I tap the brakes, it clicks under the shift console between the front seats under the shift lever. I placed my hand around the plastic housing on the shift console and could feel the tap as I depressed the pedal repeatedly.
Any idea what that is? Only in Park. Solenoid?
mln01 Jan 23, 2016 07:03 PM
That is what it is supposed to do. It's always done it or you would not have been able to shift out of Park. You are just highly sensitive to your truck today. :-)
When you step on the brake pedal the brake light switch not only turns on the brake lights, it triggers solenoid under the shifter that allows you to shift out of park. All good.
jamieb Jan 23, 2016 07:22 PM
Super highly sensitive. :-).
Thanks!
number9 Jan 24, 2016 01:22 AM
What is "B" option and does it produce a pronounced clicking for the sensitive afterwards? Did a search and found nothing.
jamieb Jan 24, 2016 09:29 AM
Sorry, option B to fix the 3 amigos in the SLABS module. I unclamped brake lines from the plastic clips and thought maybe one was loose and jiggling
number9 Jan 24, 2016 12:18 PM
Thanks. Will probably meet those guys down the road.
Fallstaff Jan 24, 2016 05:26 PM
Had the same panic. Its a sound you only notice when you've just changed something and are being hyper-sensitive. :)
jamieb Jan 24, 2016 09:24 PM
Yes! The "oh crap! What happened and is it serious???"
