Clock
The clock on the dash is supposed to light up right? Mine doesn't. Fuse is good, obviously. It work, just no light. Thoughts on a fix???
Trying to get my RAVE cd iso image burned onto a disk as well. No luck with that yet. |
RE: Clock
I have the exact same problem.
RE: Clock
small light bulb behind clock, get at local auto shop or from rover connection. becareful removing clock, tabs break easily
RE: Clock
ORIGINAL: zerochills small light bulb behind clock, get at local auto shop or from rover connection. becareful removing clock, tabs break easily |
RE: Clock
I've got the same issue. If oyu get into this, please document with pictures!
RE: Clock
ORIGINAL: jmt I've got the same issue. If oyu get into this, please document with pictures! Does anybody know if it comes with the instructions on installing it? Could anybody post pictures of taking the dash apart to get to the clock? |
RE: Clock
may want to look through recent past post, I know I saw Disco Mike had post a reply in regards to this, do not remember how in depth it got.
RE: Clock
remove the cup holder and coin/ash tray. You can pry the clock out then.
Also, get the bulb at the dealer. I paid $7 for mine. AutoZone tried to sell me the wrong wattage bulb that wouldn't even fit. Just run by the dealer. |
RE: Clock
Does this apply to the 03 Dash as well? Not sure...
RE: Clock
i am glad i am not the only one with this problem. it annoys me at night not knowing what time it is.
