codes????
FYI
P0171 " SYSTEM TOO LEAN BANK 1"
P0174 " SYSTEM TOO LEAN BANK 2"
Usually this would indicate a faulty MAF as stated above.....
P0733 "gear 3 incorrect ratio"
P0734 "gear 4 incorrect ratio"
it's highly unlikely that the gearing has magically changed....but more likely that the maf has caused your ecu to be a little goofy.....
do you have a code reader so you can clear these yourself ?
