condenser cooling fan motor
Hello, all,
I'm a newbie, but have read a lot of the threads and learned more than I thought possible! This is a great aide to keeping the Disco's going!! My question: I've noticed the condenser cooling fan motor has gotten louder lately when running. Is it possible to lubricate the motor with something like 3in1 Oil? If so, where would you put the oil? Thanks! PS: mine's a 2004 Discovery II. |
i did not see any place on my 2000, just replaced it.
When it fails (which will be soon) you won't have the extra cooling needed when slow or stopedm especially with AC on. So engine could overheat. A $80 electric motor is a lot cheaper than the gasoline powered aluminum one under the hood.
Roger that on the $80.00 electric motor!
Make sure whatever you buy it equals or exceeds the factory fans flow rate.
See my write-up on "Does your A/C condensor fan work"? The motors are available at some of the local big chain auto part stores. If yours has been siezed up as my were for sometime, any replacement motor is going to be an improvement. VDO brand at O'rielly Auto is what I used and they are great.
Originally Posted by 0304Disco
(Post 342316)
I also ran across another thread where someone used a ac delco p/n 15-80341 they got off amazon for 76 bucks. Mine is locked up also. thanks |
Originally Posted by GreedyRover
(Post 342334)
So you used the VDO p/n PM9115 on a DII? I seen a thread on the discoweb site but that guy had a DI. If that one will work on my DII pep boys has them for 46 bucks.
I also ran across another thread where someone used a ac delco p/n 15-80341 they got off amazon for 76 bucks. Mine is locked up also. thanks I search around looking for the Part Number to replace the electric motor. XRacer or RacerX had suggested that a Four Season 35110 motor would work. So I ordered one from Advanced Auto Parts for $71.00 delivered knowing if it didn't work the most I'd be out is $10 buck for shipping. Had some problems with the order and wanted to get the job done so I called O'reilly's and they told me the Siemens VDO brand PM9116(also available from amazone for $63.00) was the same and that they could have me two unit the next day so I placed the order and they met the price of Advanced. The VDO unit looks identical to the stock motor removed and I would suggest these over the others listed. I also ran across thes PN's after the fact on another forum AC Delco - 1580341 / NAPA- BK 6552105 /. On the install, using a dremel tool and a drum sanding wheel (Pic atached), you'll need to sand off about 1/16" off the back side of the plastic fan hub material because the new motors shaft is a bit shorter and the fan will rub on the shroud if you don't. You'll need to cut the connecters off your old unit and install on the replacement motor. Red and Black are commonly Positive and white and Blue tend to be Negative. If you get the polarity incorrect, the worst case is your fan will spin the wrong way. After you get it wired up make sure the the fan is moving the air toward the engine. If your not sure take a paper towel and see that the fan wants to suck it in. If your motor is sieze you've also blown your #5 40amp fuse located in engine compartment fuse box. From start to finish your looking at about and 1.5 hours on this job. |
Thanks for all the info! When mine dies, I'll know where to go and what to do. As I said earlier, I learn more on this site than I thought possible!!
call paul grant. i just bought 2 used from him for my d1 cheap. they work great.
| All times are GMT -5. The time now is 03:23 AM. |
