-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Coolant (https://landroverforums.com/forum/discovery-ii-18/coolant-10607/)
gsgtsg Dec 14, 2007 12:58 PM
Coolant
Discovery V8 ESyear 2000 model.
The manual states to use one of the below coolants.
1) Havoline Extended Life Coolant (XLC)
or
2) Ethylene glycol based anti-freeze (containing no methanol) with Organic Acid Technology (OAT)
Please advise if this is a special coolant or can it be obtained from Halfords or other motor car care outlets.
Thanks.
98roverguy Dec 14, 2007 01:00 PM
RE: Coolant
Use Dexcool
willstevens Dec 14, 2007 02:57 PM
RE: Coolant
I agree, Dexcool is the stuff to use and you can find it just about anywhere.
Disco Mike Dec 14, 2007 03:32 PM
RE: Coolant
DexCool is the OAT product and is made by a few different manufactures, sold at most auto parts stores.
Spike555 Dec 14, 2007 08:57 PM
RE: Coolant
http://www.girardgibbs.com/dexcool.html
Read this first.
okdiscoguy Dec 14, 2007 08:58 PM
RE: Coolant
Dexcool is corrosive, true. But only when exposed to air.
Spike555 Dec 14, 2007 09:06 PM
RE: Coolant
And can you gurantee that no air will ever get into the cooling system? Your cooling system is a closed system, but they do develop leaks that you may not find until it is to late. Bad radiator cap for example.
In my humble opinion a $1000+ dollars for new head gaskets isint worth the risk of using Dex-Cool.
okdiscoguy Dec 14, 2007 09:09 PM
RE: Coolant
HEad gaskets don't blow because of Dexcool, it is because they are Rovers and have a thin sealing surface for the jacket on the head and a poor material composition for the gaskets. D1's need gaskets as much and as often as D2's and they didn't run Dexcool from the factory..
Spike555 Dec 14, 2007 09:25 PM
RE: Coolant
OK. I'm just lucky maybe? I dont know, just asking. Mine (D1) is all original with 170k on the clock. So, I dont know, I still wont use Dex-Cool though.
geotrash Dec 15, 2007 03:28 AM
RE: Coolant
I dunno guys...my thinking is really unsettled on this topic. Why is Dexcool so strongly recommended by some and opposed by others?
If it's chemically corrosive when exposed to air, there is a lawsuitallegingnylonseal damage in other engines,andRovers are notorious for cooling system leaks and breaches, what makes Dexcool a better choice than standard ethylene glycol based coolants if I plan to change it every 30K anyway? I'd really like to find an objective answer to this question!
How corrosive is it and what makes the Rover cooling system incompatible with standard coolants?
Cheers,
Dave
