coolant bleed help
coolant bleed help
Background: 9 month old radiator, ZERO coolant leaks or any issues prior to changing my Tstat to the 180 degree model 3 days ago. SO, I tried to bleed the coolant of air according to the RAVE & DM's instructions (stone cold, overnight engine-bleed screw out-elevated exp tank, etc) even RE-read it to make sure it was followed properly- THAT was the first time...
Still had waterfall sound, so did it the next morning with passenger front tire elevated on ramp-- STILL had waterfall sound-- UGH!
Did it AGAIN this morning and still have waterfall sound...3 times now...
What am i missing?
Thanks crew
What am i missing?
Thanks crew
Its no extra truck or smarter than anyone else my friend! Its posted about 100,000 times. Just sometimes its easier to have someone talk you threw it vs read it.
If you need help you can go to the search bar and type...how to bleed cooling system.
If you want me to walk you threw it leave me your phone number and a convenient time to call you and I will gladly do just that.
