coolant expansion tank
Old Jun 30, 2014 | 05:32 PM
Tomzsix's Avatar
Default coolant expansion tank
Is it pretty straightforward when removing the tank?? Just two hoses to remove, then refill with coolant? And those funky clamps....how do they come off???
Old Jun 30, 2014 | 05:42 PM
Externet's Avatar
Pull its rear side up about 2-3 inches, then maneuvre its front out of the craddle, the bottom hose will be bothering under, but work on it.
Old Jun 30, 2014 | 05:46 PM
Tomzsix's Avatar
how do you remove those clamps?? And what about bleeding the system that has some people dumbfounded? Including me.
Old Jul 1, 2014 | 12:46 AM
MarkSF's Avatar
You remove them by sticking a screwdriver in the gap, and prying them apart. Then throw them away and replace with normal jubilee clips.
Old Jul 1, 2014 | 10:11 AM
schwaggy's Avatar
Have you searched the Forum? There's several threads about this procedure. Search for "overheating" and "bleeding coolant" and "Expansion Tank" and you should find what you need.
Old Jul 1, 2014 | 10:29 AM
SuperSport's Avatar
Slightly different from our setup, but very similar.
Old Jul 3, 2014 | 06:23 PM
Tomzsix's Avatar
Well...that video made it simple. However.... because of other posts of frustrated people, I took it in to my mechanic. $74 later, my new reservoir is on, and I have peace of mind. Sometimes the forum can be swamped with the correct answer. But I do very much appreciate every ones help.
aguison
Nov 16, 2012 09:29 AM
jfry75
Sep 12, 2009 02:40 PM
brooksa
Jan 17, 2009 03:09 PM
twalter87
Sep 9, 2007 08:47 AM
