coolant leak, time to look deeper
Well I thought the coolant outlet gasket by the alternator was where my leak was coming from. Pulled off pulley's on right side and its mounting block to get a better look. (of course its just pulled forward against the fan since I didn't pull the fan yet. was hoping I wouldn't have too. The leak is below the the outlet and toward or against the block. I keep thinking its the head but my mechanic friend thinks the engine is running too smooth to be indicative of that. Its definitely on the right side. Anywhere else to look? I'm finding the leak by using a pressure test at about 15 pounds pressure. I can see the drips from below but just having a hard time identifying the exact source of the leak.
How much coolant are you loosing? Your engine will or can still run great with a very small head gasket issue. You say you can see drips from just below and stopped " just below where"?
Wouldn't trust that mechanic, go do a coolant pressure test, you will find the problem real fast.
Ive being 45 years on the trade, , I,m a senior mechanic with most experiance in CANADA
I sugest that your leak my come from FROST PLUGS look under the exhaust manifold area jl |
pressure test
Originally Posted by Disco Mike
(Post 337161)
Found a leak in another hose today which was making it hard to keep the pressure up so will get that one locked down and try again so maybe I can get a better flow out of it. When the engine was warm, it was a steady stream. However, it didn't seem to really start up like that until the engine was warm. Now with everything off, just doing it with the pressure tester. |
leak
Originally Posted by jaimeluciano
(Post 337163)
for Mike
By the way Mike, my friend who is the mechanic never said it couldn't be the head, just with our quick look the other day with the scope, made him think it was the oring gasket on the outlet. Especially since the engine was running very smoothly.
His statement about it running to well to be head gaskets is what I was referring to, an engine can run well with a minor head gasket leak and never give any indication of a problem, other them a coolant issue of course.
timing chain cover is a pretty common leak on these things, a lot of times it will blow up under the ac compressor or alt. making you think the leak is high than it really is.
That would make sense with what I am seeing. Will check that out.
| All times are GMT -5. The time now is 05:00 AM. |
