Coolant Refill Issue
Old 09-07-2020, 01:18 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Originally Posted by orderofelim
Yes. Wondering if I may have a faulty thermostat.. It's brand new from Atlantic British.
A thermostat is closed when cold so the only coolant flow thru it will be thru the tiny weep hole. Remove bleeder from the upper T & and either fill thru there or fill thru the reservoir until it flows out of the T.
orderofelim (09-08-2020)
Old 09-07-2020, 08:09 PM
boston4's Avatar
I like to remove the bleeder screw and tank cap and then squeeze the top hose to push air out of the bleed hole. Then, cover the hole with your finger and release the hose - it'll suck the coolant in from the tank. Easier than trying to pour coolant into the tiny bleed hole.
The following 2 users liked this post by boston4:
Jason_B (09-08-2020), orderofelim (09-08-2020)
Old 09-08-2020, 01:20 PM
orderofelim's Avatar
I got it running! Thanks for the responses. Was just overthinking it.
Richard Gallant (09-08-2020)
Old 09-20-2020, 02:43 PM
mln01's Avatar
What was the solution?
Old 09-20-2020, 04:37 PM
I just filled it through the bleeder hole. Didn't feel like messing with the reservoir. Engine seems to be doing fine but taking it into my local guru to give it a once over.
Old 10-03-2020, 09:10 PM
Wheelspin's Avatar
Thanks to all those who give advice, I’ve not done any maintenance on cars in over 10 years, just did the throttle bypass and replaced top hoses and thermostat, I’ve read and done the trick of lifting the overflow tank till water comes out the bleed screw hole.
that was yesterday , took out the bleed screw was a little air and topped up through the hole with coolant, can’t believe how much fun this is
Old 10-03-2020, 10:07 PM
zuke's Avatar
I would probably not use a garden hose. 50-50 Preston and distilled water. But thats just me.
Old 10-05-2020, 11:38 AM
shanechevelle's Avatar
Are you following the RAVE procedure for filling and bleeding the cooling system? Releasing and raising the coolant reservoir so the bottom of it is above the bleed screw? Opening the bleed screw and filling from the reservoir until coolant flows from the bleed screw opening?
The RAVE procedure has never failed me. No need to raise the front of the truck. No need to stand on one leg while whistling the theme from The Andy Griffith Show. Ni need to wear a tin hat. No need to fill from the bleed screw.
except when your plastic hoses become brittle and break costing you money when you disconnect the bottle.
I used to raise my truck, bleed it, and be done without moving any bottle.
Factory stat.
Driving the truck up a hill is far easier than lifting the bottle and doing all the fill through the bleed hole...
Just sayin.
Tristan Stumpf
09-10-2024 11:59 AM
SensiRider
04-23-2017 12:23 AM
BrokeRover
02-22-2012 06:13 AM
rzuluaga
02-21-2012 08:56 AM
asikuy
03-05-2009 06:57 PM
Quick Reply: Coolant Refill Issue
