Coolant Reservoir Field Repair
I've had a slow leak from the coolant reservoir side of the engine bay that I thought was a failed cap, but late yesterday it hemorrhaged to reveal it was from a crack near the base of the nipple on the bottom of the tank where the line to the throttle bottle heater connects.
The truck was only a little under three miles from home so to get it home I did what I did when the bleed screw blew out of the original top radiator hose a few years ago; I broke off the nipple and crammed a golf tee in the hole, then held it in place with a nice duct tape wrap, refilled and drove home after also plugging the throttle body line with a short 5/16 bolt and the hose clamp. I left the cap off because the last thing I wanted was pressure in the system that might force out the golf tee. But that wasn't the real field repair.
This morning I removed the reservoir, flipped it over and filed down the stub to be reasonably flat. Then I found a screw that fit the hole (#10x¾) and after testing it for a snug but not too tight fit wrapped it in Teflon tape and installed it in the hole. The reservoir shell and the stub gave me perhaps 3/8 to 7/16 of thickness for the threads to grab. Worked like a charm, and after driving around for a while this afternoon there’s no sign of a leak.
I’'ll order a new tank Monday but this technique could keep some other DII or P38 on the road someday.
DiscoCam (07-24-2016)
bcolins
03-30-2014 09:02 PM
aguison
11-18-2012 05:15 PM
