-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Crank position sensor test ??'s (https://landroverforums.com/forum/discovery-ii-18/crank-position-sensor-test-s-25225/)
possibly owner Sep 21, 2009 09:49 PM
Which plug on the ecm do you check the crank position voltage at? The ecm is in the passenger kick panel correct?
I also checked codes, it had a p1884?
Disco Mike Sep 22, 2009 09:06 AM
1884 is actually a fault code for 8 different issues and will go away on it's own when your issue is resolved.
What is your truck doing wrong, do you have a scanner that can give you real time readings, if so that is the easiest way to verify a problem.
