Crankshaft Wobble
Crankshaft Wobble
This is for a 2003 D2
So replaced water pump, oil pump, timing chain and cogs, and crankshaft seal 10k miles ago. Noticed I had some oil leaking from the crankshaft seal and my pulley was wobbling.
So I tried tightening, would not tighten anymore.
Replaced the pulley with a used one that "looked" like it was in better condition, wobbles even more.
So I'm wondering if my crankshaft bearing are bad. I'm really at a loss here. I do have a rough idle as well, and shaking goes away when I rev it up
One thing to consider is that the pulley, crankshaft, and flywheel are all externally balanced together with the pistons, conn rods, etc. If you replace a component, the engine should really be re-balanced. However, if you notice on the harmonic balancer there is a weight crimped onto it... could be 5g, 10g, or whatever. Make sure to put the weight onto the new pulley in exactly the same position.
Also check the rubber damper on the pulley to make sure it isn't cracked, warped, or damaged.
Could it be my crank bearings that are failing?
I have checked everything else. Sensors, air leaks, oil, everything is good except for my idle and my harmonic balancer wobble
If the bearings were worn to the point that the crank could wobble, your oil light would be on pretty much all the time. Engine would sound like hell too.
How much wobble are you seeing? Did you verify that everything was running smooth and true right after the work 10K ago?
