Crazy whine from the transfer case
My 2000 D2 was finally driving well (after dozens of hours spent rebuilding the engine, suspension, etc.), and just as I thought I can finally take a break, the transfer case sprung a leak and started letting out an insane whining noise at about 35-40mph. Has anyone had this kind of an issue? I can't locate the leak - it seems to be coming from the top of the case (I really don't want to rip out the center console just to have a look).
I do have the center diff lock levers from D1 installed - could that be the problem? I've changed the gear oil a while back and it is currently royal purple 75W90R GL5. Anyone had an issue like this (leak, whine, or both)? Really appreciate any input. Thanks! |
If it suddenly started leaking really bad check your breather tubes. They frequently get melted shut on the manifold, passenger side by the fire wall. When this happens your tranny and/or transfer can leak like crazy. Mine did. Fixed the breathers and it stopped.
yep happened to me and the t case blew the oil out all over the bottom of the truck and then it self destructed
That sounds great!! Good that I stopped driving it. I'll check out the breather tube melting situation. I did clean/unclogged it couple of years back when installing the D1 shifter...
make sure you have gear oil in there too !
Checked the breather tubes - all in good shape there. I guess I'm pulling the center console out...
I’m having the same issue in my transfer case now. All of the sudden it has a whining noise when I get to about 30mph. I’m leaning toward a bearing going bad. Fluid level is good, diff-lock operates normally, high/low works fine.
| All times are GMT -5. The time now is 08:54 AM. |
