Cruise Control
Cruise Control
I just got a 99' disco II. Reading the other post I found out what button is cruise control but I still can not get it to work. Anybody have any idea's. I called the local LR dealer but they said it could run any where for $100 to $700, anything from a fuse to the wiring. Second question anybody know what fuse it could be. Any help would be great.
Check your vacuum lines. I found all three of mine split right at the t-connector on the driver's side inner fender well. One line goes to the actuator bellows on the throttle body, one line goes forward to the vacuum canister/reserve canister, the third line goes through the firewall to the brake pedal switch. If you find a split line replace all three - I fixed mine for about $4... quite a savings over your dealer quote.
Evan5291
11-21-2017 07:59 AM
southfloridadiscoII
06-28-2009 11:03 PM
flowers
04-12-2005 04:03 PM
