-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Cruise Control not Working (https://landroverforums.com/forum/discovery-ii-18/cruise-control-not-working-8488/)
bklahl 08-25-2007 01:59 AM
Hey Everybody, I have a 96 Disco and I have a problem with my Cruise Control. It worked when I bought it a year ago. Now it doesn't work, it used to work sometimes and then shut off on its own. Now I get nothing. Anyone haveor had the same problem and how do I fix it.
Thanks
tailchaser0527 08-25-2007 04:02 PM
RE: Cruise Control not Working
check all of the vaccum lines going to the unit.. 75% of the time this is the prob if u don't have a fuse blown.
bklahl 08-29-2007 02:06 AM
Where should I be looking under the hood? Is there a unit for the speed control or are they on something else?
okdiscoguy 08-29-2007 08:36 AM
There is a control unit in the front LH side. It is under the metal in front of the air box. There is a line going from there back to a T around the brake booster. One line goes to the vacuum controller (black diaphragm)on the throttle and one line goes through the firewall to the brakelight switch.
bklahl 08-29-2007 11:20 AM
Thanks for the Info DiscoGuy. I will check it out today.
