D2 Cranks but will not start
Good day ... I need your help as I have read all of the threads that I can find and followed the advice and recommendations given and still can't fix the issue of my 2000 MY D2 cranking but will not start.
Using my OBD 11 Tester, it does not detect any DTC's and the Check Engine light is not illuminated.
What have I checked and or replaced:
Removed a plug lead and checked for spark using a spark tester and also with a new spark plug: No spark checked the CPS by measuring the voltage supply and resistance (as per Disco Mike's post) and they are good. Also removed it and refitted it to another D2 which started to confirm that it is not faulty. Fitted the CPS from the other D2 and still no spark.
Fuel Pump: Checked voltage, ground and pressure. All okay but just to be sure swapped with new Bosch pump that I had on the shelf
Changed over Cam Position Sensor, MAF, Fuel pressure regulator, knock sensors, inertia switch, all fuses and relays.
Checked all grounds that I could find and they were all good
Removed and checked both fuse boxes (engine bay and drivers area) for corrosion/loose terminals - All okay
Checked connectors at ECM and BCM
Central locking and alarm system functions correctly
Hopefully someone can help me as this is driving me and mechanics crazy.
Thank you
Thank you
Check fuse #14 in drivers compartment fuse box (coil pack fuse) for continuity and power with key on and relay R4 (ignition relay, right lower). Bought a Dll, $500, wouldn't start, had fuel/cranked strong...but no spark. Checked the coil pack fuse #14, good, went to swap relay and as soon as l touched it...it felt out in my hand. Pushed it back in and she fired right up.
l know you said you pulled fuse boxes looking for short to ground or loose connections...but l didn't read where you checked fuses, fuseable links or relays.
Good luck.
Good luck.
Jjcopen (08-27-2021)
Good luck.
Good luck.
Fuse 14 has continuity and power with key on. Replaced the relay with one from the other D2. Cranks but still no spark.
As part of the elimination process, changed out all of the relays and related fuses in the engine compartment fuse box with those from the other D2. Cranks but still no spark
Thanks
