D2 front driveshaft replacement
I see a special tool sold by lucky8 and AB. Is it necessary? Just looks like an extension
9/16th wrench, a few extensions and a ratchet and you'll be good. I find it easiest to put the front end on jack stands, and jack up one side of the rear axle so the wheel is off the ground. Lay under the truck and use your foot to spin one of the front tires and you'll be able to get the driveshaft to turn making accessing the other nuts a little easier.
Not really but you need 2 similar sizes |
I have an electric impact gun so that should help
Originally Posted by Ben Matheson
(Post 665297)
I see Lucky 8 has their front drive shafts down to $188 at the ebay store. Is there any negatives to their drive shaft?
Originally Posted by Big Jim Swade
(Post 665317)
