D2 Intake "What is this for" Question
Old Jan 22, 2017 | 04:54 PM
twin6's Avatar
Default D2 Intake "What is this for" Question
Replacing my head gaskets on a 2001 D2 with 175K miles.
While preparing to remove the intake manifold I could identify two of three ports on the passenger side. The port that is pointed to by the red arrow has no hose attached. Can anyone tell me what it is?
Thanks!
Old Jan 22, 2017 | 05:12 PM
LR03NJ's Avatar
Thanks!
SAI control valve. It splits to both sides of engine through a small hose usually wraped with plastic cover.
Old Jan 22, 2017 | 05:21 PM
twin6's Avatar
Thanks. My 2001 D2 does not have SAI so is the port just plugged?
Old Jan 22, 2017 | 05:34 PM
LR03NJ's Avatar
yes..
Old Jan 22, 2017 | 05:56 PM
chubbs878's Avatar
If That inlet is wide open then you have to cap it off; I can't see from the picture
Old Jan 22, 2017 | 06:18 PM
Luckyjayb's Avatar
thata also the port most people use to kill all the mosquitoes in their neighborhood
Old Jan 22, 2017 | 06:45 PM
mln01's Avatar
It should be capped. If not I'd expect you'd be getting lean codes (P1171 & P1174) due to unmetered air entering the intake manifold, which would likely hurt gas mileage as the ECU tries to add fuel to get to the designed air/fuel ratio. It's interesting to me that the '99-'02 DIIs have that port since I think SAI wasn't introduced until 2003. I might be wrong about that; California trucks may have had SAI from the beginning. I'm just grateful my truck doesn't have SAI.
Old Jan 22, 2017 | 06:47 PM
mln01's Avatar
Cute.
Old Jan 22, 2017 | 06:54 PM
Luckyjayb's Avatar
Originally Posted by mln01
Cute.
Well that seafoam induction cleaning. I call it skeeter killing
Old Jan 22, 2017 | 08:17 PM
mln01's Avatar
I understood the reference, I just wondered how many of the newbies do.
